Discussion topic: Sky glass won’t power on after power cut
This message was authored by: sweetbriarhouse
We had a power cut and now sky glass won't power back on. The socket works and I have tried another working socket. Tried the reset procedure but nothing will get it to power in ie no red light. Anyone else having problems or advice please.
Re: Sky glass won’t power on after power cut
Try the recovery procedure in this Sky help article.
Try it a few times, if it does not  work first time.
https://www.sky.com/help/home/sky-tv/sky-tv-glass/fixing-a-problem-sky-glass/fixing-sky-glass-tv/art...
This message was authored by: peter-marlow+1966
Have you checked the fuse in the plug ?
P c marlow
Have changed  the fuse in the plug ?
P c marlow
