Discussion topic: Sky glass tv with sky Q box
This message was authored by K4yl2 This message was authored by: K4yl2
Hi,
i have the sky glass tv with sky q, not the streaming. Anyone know whether my channels will be affected when sky remove SD, or whether i need to update my sky q box, ive had it since 2018.
Re: Sky glass tv with sky Q box
@K4yl2
The withdrawal of support for non-HD Sky+ boxes has no impact on Sky Q.  It's not a 'removal of SD': it's the end of a particular encoding format used by antique hardware.
K4yl2
Ok then, thank you. Glad i dont have to contact for a new box, i thought i would lose most my channels for a bit then 🤦🏼‍♀️
This message was authored by peter-marlow+1966 This message was authored by: peter-marlow+1966
You can't  have a sky glass  subscription, and a sky q subscription  at the same time, as soon as you activate  the sky glass  subscription, your  sky q subscription  will  stop, but for that month  you will  have 2 subscriptions to pay and sky will  want the sky q box back
K4yl2
I dont have 2 subscriptions, i have a sky glass tv with a sky q box as stated, i couldnt get on with the streaming on glass as i couldnt record anything, so i kept the tv which is added to my bill, and went back to Sky Q for my channels.
Glass TV is just the actual tv, with my sky q connected to it through my wifi
Ok I see, sorry for the mistake  on my part
