21 May 2023 01:28 PM
Posted by a Superuser, not a Sky employee. Find out more@Kevin-7248 I used to get 475-480mbps but there was a problem with the whole Island (Jersey) infrastructure which had an effect on all the local ISPs.
I noticed the problem as my Glass suddenly started experiencing the stuttering and freezing which I had never had before so I checked my speed and found it had dropped to 7mbps.
I called into my ISP and was advised the problem was Island wide and was being looked into. It was soon fixed but since then my speed is only around 450mbps ☹️. I will pop into their shop when I am next passing to see if this speed common.
21 May 2023 01:33 PM
Posted by a Superuser, not a Sky employee. Find out moreBe thankful most I can get in the Welsh valleys is 35mb FTTC .....
21 May 2023 01:39 PM - last edited: 21 May 2023 01:41 PM
Posted by a Superuser, not a Sky employee. Find out more@Jporch316 Believe me I know how lucky I am 😀. The whole island is on fibre 500 or even 1gb which is mostly used by businesses but is available to households if you want to pay the extra.
It is also a very stable service which coupled with the speed is why I believe I have very few problems with my Glass.
21 May 2023 01:48 PM
@Fothergill1 Well if you put it like that there's no argument there, unless they are providing a temporary fix before fully repairing. But I'd get onto them just in case it's something that can be resolved from a technical standpoint that they've not adjusted and powered down your line 😋
FTTC is horrid. FTTP is needed all over the country OR a big investment in black spots for the likes of satellite provided internet.
21 May 2023 10:21 PM
Have problems with Sky Glass freezing, using ethernet cable linked to sky router with a decent Internet speed. Glass froze but I was watching football in another room on the puck and it was fine. Wonder if this is a processor problem with sky glass TVs
20 Jul 2023 11:28 AM
I have Sky fibre and my router is connected by Ethernet into my Sky Glass TV but I'm getting problems with freezing on UHD, especially Sky Sports which is really annoying. When I switch to HD it works fine but I want UHD!
20 Jul 2023 11:45 AM
@Gary2054 wrote:I have Sky fibre and my router is connected by Ethernet into my Sky Glass TV but I'm getting problems with freezing on UHD, especially Sky Sports which is really annoying. When I switch to HD it works fine but I want UHD!
Make sure that WiFi is turned off on the Network settings on your Glass TV.
Also, check what speed is being received by the TV - to find out, open the Netflix app, navigate to the Get Help menu and run a network test. Sky advise a minimum of 35Mbps for UHD to stream with stability.
20 Jul 2023 12:10 PM
Thanks for your reply. I've turned off WiFi on the TV. It did its usual thing... ran okay for a bit on UHD and started freezing again 🙄
I checked on Netflix (didn't know about that so thanks) and the speed is 71.19 Mbps.
20 Jul 2023 12:18 PM
@Gary2054 wrote:Thanks for your reply. I've turned off WiFi on the TV. It did its usual thing... ran okay for a bit on UHD and started freezing again 🙄
That's more than enough speed. Don't know what else to suggest I'm afraid. Glass just seems to be problematic with UHD streams for quite a few people. Give Sky a ring and see if they can suggest any further troubleshooting.
20 Jul 2023 12:31 PM
Thanks anyway. I learned a few things from you!
20 Jul 2023 12:33 PM
@Gary2054 wrote:Thanks anyway. I learned a few things from you!
No problem. Good luck! Hope you get it sorted.
20 Jul 2023 04:11 PM
Don't know if anyone has tried this but I turned off the eco/motion setting and it seems to have resolved the freezing issue.
Would be interesting to see if the community is still having the freezing issues with and without the setting on.
Regards
20 Jul 2023 04:37 PM
Posted by a Superuser, not a Sky employee. Find out more@Grolschy Like you I have this option turned off and TBH I very seldom get any freezing and when I do it is generally because I gave too many conflicting commands on the remote and have confused the system.
I actually turned off all the option in the Start up & Standby menu except for the Networked Standby mode which I turned on. I did this not long after getting Glass 12 months ago and it resolved a lot of annoying issues.
20 Jul 2023 04:56 PM
I have kept my wifi on and just disabled the carbon neutal/motion/sleep mode in the settings. I just have a feeling the freezing is related to the eco mode. Let me know if this makes sense.
20 Jul 2023 05:12 PM
I'll give it a go 👍
(Yes it does make sense... I previously disabled the motion detection as every time some walked past the room the TV came on 🙄)
