This discussion topic has been answered Discussion topic: Sky glass air hello sky
Message posted on 19 Oct 2025 07:40 PM
I have been having issues using voice control without the remote on a sky glass air.
today I was told by sky that voice control without the remote is not available on the air tv!
it's not what I was told when I signed up.
anyone else had this
Message posted on 19 Oct 2025 07:59 PM - last edited: 19 Oct 2025 08:02 PM
That's not correct. Both Glass Gen 2 and Glass Air have hands free voice control, as listed on the Sky side-by-side comparison.
Message posted on 19 Oct 2025 07:58 PM
Re: Sky glass air hello sky
Unfortunately whoever from Sky told you that clearly has little understanding of Skys products.
The Glass Air does indeed have voice control.
It might be worth checking to see if voice control is switched on in the settings ( the option is found under Privacy in the settings) or if it is perhaps switch it off, reboot the TV and then switch it back on again.
Message posted on 19 Oct 2025 08:08 PM - last edited: 19 Oct 2025 08:09 PM
Also check the 'disable microphone' button on the chassis hasn't been accidentally toggled
Message posted on 20 Oct 2025 06:56 AM
Hi @Ray572
this worked when I lost voice control on my glass gen 1
Switch tv to standby (either with remote, or with button on side of set)
Switch off at plug
Switch on at plug (no waiting necessary)
When red standby light comes on, press Home button on remote.
