4
This discussion topic has been answered Discussion topic: Sky glass air hello sky
This message was authored by: Ray572
I have been having issues using voice control without the remote on a sky glass air.
today I was told by sky that voice control without the remote is not available on the air tv!
it's not what I was told when I signed up.
anyone else had this
Re: Sky glass air hello sky
That's not correct.  Both Glass Gen 2 and Glass Air have hands free voice control, as listed on the Sky side-by-side comparison.
https://www.sky.com/glass/air
Unfortunately whoever from Sky told you that clearly has little understanding of Skys products.
The Glass Air does indeed have voice control.
It might be worth checking to see if voice control is switched on in the settings ( the option is found under Privacy in the settings) or if it is perhaps switch it off, reboot the TV and then switch it back on again.
@Ray572
Also check the 'disable microphone' button on the chassis  hasn't been accidentally toggled
This message was authored by: Jporch316
Hi @Ray572
this worked when I lost voice control on my glass gen 1
Switch tv to standby (either with remote, or with button on side of set)
Switch off at plug
Switch on at plug (no waiting necessary)
When red standby light comes on, press Home button on remote.
Answered - Go to Answer
