19
Discussion topic: Sky Glass reducing WiFi
Re: Sky Glass reducing WiFi
@DonaldClan
The WiFi Guarantee specifically excludes external locations, but you might find other places within the main building are now below minimum speed.
DonaldClan
This message was authored by DonaldClan This message was authored by: DonaldClan
Good call
This message was authored by TimmyBGood This message was authored by: TimmyBGood Answer
@MarkGoldsmith
Thanks: it's come up here a few times before, and also in the Broadband forum where a household has cancelled Q television and then found the WiFi from their Sky Hub has apparently nosedived in speed and coverage when it's actually the loss of the Q box hotspot(s) and mesh function which is the cause.
This message was authored by MarkGoldsmith This message was authored by: MarkGoldsmith
You would hope Sky would point this out for any customers changing from Q as it's certainly something most customers wouldn't naturally think about
Sky Stream user. Former Sky+ HD and Sky Broadband customer
This message was authored by Exiled-in-HH This message was authored by: Exiled-in-HH
@DonaldClan are you getting 3 Mbps in every room.... not a particularly high bar to reach🤔
You'd be better better getting power line adapters to distribute wifi or wifi repeaters if you want more than a measly 3 Mbps in every room😉
Exiled in HH
