4306
This discussion topic is read only This discussion topic has been answered Discussion topic: Sky Glass Power up Issues 19-9-24
Locked
This message was authored by: Operator2024
Re: Sky puck light just flashing
Same issue for me too.  It's getting ridiculous now 😡. Sky need to sort this out.
This message was authored by: Ricardo414
Re: Sky Glass Power up Issues 19-9-24
That's outta rubbish
This message was authored by: LOLO8
Sky stream puk still won’t switch on
Tried to restore several times following instructions but still puk won't switch on. There has been a notice since 19th that there is an outage in my area but still not fixed. That's 2 days without sky channels. How much longer I wonder. Still getting notice that there is no signal to pull???? Cannot get response from sky on phone. So anyone have any suggestions?
This message was authored by: Charles571
Pay a lot of money for sky and it’s not working been working all then it just stop and without load
Pay a lot money for sky glass works all day then just stops working and won't load
If the recovery process isn't working for you, you'll have to call.
Re: Pay a lot of money for sky and it’s not working been working all then it just stop and without l
Hi @Charles571  This is a widespread issue but Sky have come up with a solution which works for most but it seems not all subscribers.  There is a very comprehensive thread at THIS location.  Have a look at the Answer (post 2) and follow the link to the next page and then select Glass or Stream and follow the recovery process.
Most people who have an issue seem to get stuck at either the PIN or activation steps.  If asked for a PIN just ignore it and unplug your Glass TV and then plug it back in again after about 30 seconds.  After it reboots you should be able to continue the recovery procedure.
When you are aske to enter an activation cove ensure you are logged into your My Sky account or you will get an Oops..... error message.
It had me up and running again in just a few minutes.  Good luck.
what if sky glass is three years old will they replace for new one???????
Yep done that, over 2  and a half hours on the phone today, yesterday over one and half hours. To be told nothing they can do, so what now. It's a serious joke tbh 😡
I don't believe that scenario has arisen yet. But if they were to replace it, it's very unlikely to be with a new one.
This message was authored by: Jporch316
@Ricardo414 wrote:
try that couple of tims nothing happen
Pull your plug out
pressand hold the standby button on the bottom right  of the tv as you look at
put the plug back in while still holding the standby button
keep holding the standby button until the light at the front of the tv starts flashing
let standby button go
follow on screen prompts
This message was authored by: Dannyh35
3 days now ive had that 'oops there is a problem' and can't reactivate it to watch! SKY is an absolute joke for the money it costs us!!
You need to sign into your sky account with the correct sky id before you go to the activation page
This message was authored by: TomCreswick
My tv says it can't activate, try again later. Any suggestions please?
This message was authored by: NeilM46
I have Sky stream and can get the puck to restart using the info on the website. Think is now when it asks me to link my account using the code I go to sky.com/activate and it just shows there is a problem. Anyone else with same issue?. I was on hold with sky this morning for 1h 45 and when I eventually got through the agent just said I had to wait for it to be fixed and there was nothing that can be done
This message was authored by: Paul+Dray
Log in here first: https://www.sky.com/signin
Then do the activation here; http://sky.com/activate
Make sure you are logged in to the main Sky website. Just crossed my mind that some people may think logging in to this Sky community forum is the same thing. It's not, it's separate.
Pioneer Kuro PDP-LX5090 50in Plasma TV | Yamaha DSP-AX863 SE AV Amp
Sky Stream Puck; Build: QS037.045.01P | Sky Broadband Superfast
Locked
Answered - Go to Answer
