23 Sep 2024 01:08 PM
Why after 4 days of know service on our sky glass tv which we have only has 1 week and only enjoyed tv for 3 days of 7 is the porblem not been permanatly fixed , done all the fixes tips given on your web site nothing works and have repeted this several time each day since the sevice went down this is not good enough and we need answers 😪😡👎
23 Sep 2024 01:12 PM
So another morning on the phone...
Sky are aware and working on the activation oops page, however I have been passed to yet another team as they still can't fathom why my code is accepted on the website but TV doesn't move on from there.
Another round of plug in, plug out, in, out, shake it all about...
still no further on 😭
How did you manage that? It won't give me the option to connect to a network 🙃
23 Sep 2024 01:13 PM
Posted by a Superuser, not a Sky employee. Find out moreI've moved your post into a large thread discussing this issue. Sky continue to work on it. See post 2, currently showing as the answer.
23 Sep 2024 01:19 PM
Finally back up & running.
Not happy about this issue will be interested to hear what compensation is offered.
23 Sep 2024 01:21 PM
Mine is up and running again I did not read it properly you have to keep your finger on the button when you put the plug on that worked.
It would not accept my post code the issue was when we first set up the Sky acount the email address was wrong when they corrected the email address this created a secondary account. The primary account had the wrong email info one letter wrong. Sky were great I have to say took 1 hour to get through but they called me back twice to get it all up and running. As soon as they reset the primary account with the correct email address I could log in and the box for code appeared all working now .
Sky said they had several customers having problems with post code
23 Sep 2024 01:24 PM
Wait time on calls about Sky Glass down to one hour forty today. Must check when my subscription is up for renewal..........
23 Sep 2024 01:29 PM
Have you tried the recovery process here: https://www.sky.com/help/articles/sky-glass-stream-wont-turn-on ? What happens? What stage do you get to?
23 Sep 2024 01:37 PM
Posted by a Superuser, not a Sky employee. Find out moreHi @mareendavidson what an unfortunate time to start your Sky subscription. The outage was fixed (for most but not all people) on Friday morning.
If you have not already done so go through the recovery procedure HERE which is the Sky recommendation.
Good luck
23 Sep 2024 01:45 PM
Hi can any one help please we have got the sky glass we have done all the other things that people have done it comes with sky when it loads up then we press 7 an 9 for 2 seconds then it takes u to your broadband so when we put the password in it doesn't connect any help or ad vice would be much appreciated thank u matt
23 Sep 2024 01:51 PM
I had this issue where router and Internet was showing an X. I connected via ethernet cable, completed recovery and then WiFi reconnected as expected.
MikeAlanR
23 Sep 2024 01:57 PM
@lettice still not working, just done everything you said and it's still brought me back to the pin page
23 Sep 2024 01:59 PM
I just want them to cancel the agreement return my money so I can leave the and get back to normal TV and not 100 of channels of repeats ..tried booking a film last week they want £20 on top of my movies pack ..cheaper to go the cinema..anothe rip off that's what the Uk has become 😡😡
sky.com are you listening I doubt it .
23 Sep 2024 02:07 PM
@Matt19891 I had to buy an Ethernet cable and connected it from my wifi hub into the tv and it worked. You don't need to connect to Wi-Fi if you do it that way, just to get you into the tv and then you'll be able to connect it to Wi-Fi later. So hopefully you have an Ethernet cable to hand as I'm sure that will work for you.
23 Sep 2024 02:09 PM
I still can not get it to work / still getting oops message when trying to activate. I can't even get through to them to cancel subscription!
