3794
Discussion topic: Sky Glass Power up Issues 19-9-24
This message was authored by sledge01 This message was authored by: sledge01
Re: My sky puk is not working i have no sky tv and havent since 20.9.2024
Hi Paul if remember correctly I had to confirm or click something in the my sky app before the access code was accepted & then the process moved on on
This message was authored by Paulbuckland557 This message was authored by: Paulbuckland557
Sky glass successfully restored to switching on.
Log in to sky app (and tried on Web app).
Go through setup process on the glass. Get to activation code entry.
Web page/app say activated.
Glass doesn't move past screen showing code.
Only have on sky I'd which is logged in.
Tried on WiFi, tried on LAN with glass.
Tried the code entry on android phone on 5g. Windows PC on both network and paired with phone as a hot-spot.
This message was authored by SandiPatsx55 This message was authored by: SandiPatsx55
Sky glass has not worked since Thursday and I have tried all the ways to fix.
I have called twice and waited 30 mi utes each time but gave up! I know it's a technical fault and when will this be fixed?
This message was authored by HuwJames This message was authored by: HuwJames
My problem is the Sky Glass tv just doesn't switch on!  There is power to the tv.  My Sky internet and WiFi are all working ok!  Maybe a fuse blown in the Sky Glass tv?
Thanks. I'll see if I can find a checkbox and try again.
The initial process worked for getting mine to switch on. Hold power button, keep it in while disconnecting mains power. Then turn on mains power while still keeping power  button pressed.
You'll see the red LEDs blink after about 15 to 20 seconds. When they flash u can let go.
This message was authored by peter-marlow+1966 This message was authored by: peter-marlow+1966
Re: Sky glass has not worked since Thursday and I have tried all the ways to fix.
Have tried  unplugging  the tv, waiting  a few  minutes holding  the power un on the side and at the same time  plugging  the tv back in
This message was authored by Mark1707 This message was authored by: Mark1707
Sky glass won't connect
My sky glass will still not connect
This message was authored by lettice This message was authored by: lettice
@Paulbuckland557 wrote:
What's the recommendation if you are logged into my sky.
You get a message saying you are now active.
But the sky glass holds still on the page with the activation code and wont move forward....?
On the page where you enter the code, you should see some kind of back or similar key on the page ( not the browser back key), you need to do that for it to progress on screen.
You may need to scroll up and down the page to find that.
Sky Community Superuser. What is a Superuser? Click here to find out
Sky Stream (2 pucks), Sky Ultrafast + using Sky SR203 hub. Sky Protect kit tester.
This message was authored by MarkBailey1975 This message was authored by: MarkBailey1975
Re: Sky stream down 3 days
Thanks for the info I am not a sky glass customer and my puck won't even load I just get a sky symbol then it turns off wish I never left virgin now and they were horrendous I will just cancel my DD see how quick I am contacted then
This message was authored by JaqiT This message was authored by: JaqiT
Re: Sky Glass Power up Issues 19-9-24
I have followed but still can't apply code to my account been without service for 3 days surely we should have updates when I phone same answer given basically WAIT we are working on it !!!
This message was authored by Annie+UK This message was authored by: Annie+UK
Re: Sky glass won't connect
I have moved your thread to a more appropriate forum
Annie  ( Please Note: I am Neurodivergent - ASD )
That is the problem we ar e discussing on here that many  customers are having.
This is the resolution that works, that you have to do.
It has worked for many Sky Stream and Sky Glass TV customers over the last four days with the issue.
Follow the procedure exactly as described in post 2 of this thread, flagged as the Answer post from Sky.
Try holding down the button for as long as possible, it won't harm keeping it pressed longer than mentioned, but release when you see the blue screen instructions on screen.
https://helpforum.sky.com/t5/Sky-Glass-Live/Sky-Glass-Power-up-Issues-19-9-24/m-p/4757859#M147519
If you have any issue with activation during the process or entering the pin do the following;
Activation problems:
Try refreshing your browser cache or try the activate link in another browser or device.
Before clicking on the activate link, log in to your MySky account first.
Also, try this alternative link;
Make sure you have logged into your Mysky account in your browser before trying.
https://www.sky.com/productsettings/streaming-tv/activate
Also, you could try using a mobile phone, not connected to your home broadband.
Pin problems:
When at the pin stage and it fails.
Remove the power from your Puck or Sky Glass TV,  leave off for a few minutes and repower.
It will continue, follow the instructions.
This has worked for many having a pin issue
Yep same for me here no tv for 3 days I couldn't even get through to sky
This message was authored by Daniel0210 This message was authored by: Daniel0210
@MarkBailey1975
Very unwise. Sky won't contact you. Cancelling your payment method will increase your problems. Sky services (when this is fixed) will be restricted, late payment fees will be added, you won't be able to speak to Sky, you won't be able to cancel and continued non payment will result in Sky passing the debt to a Debt Recovery company which will ultimately affect your credit score.
▪️I AM NOT A SKY EMPLOYEE ▪️
