22 Sep 2024 09:59 AM
I am now on my third day without Sky glass. Although I'm in my 80's & not tech savvy I can easily read & follow the on screen instructions advising what to do to get it back. I am now on my sixth attempt & all it does is take me back to where I started. This is very frustrating considering what I am paying. I have been a customer for 50+ years and sky customer service has always been poor. This is the last resort for me so I will most probably ditch sky & go to the local pub to watch sport in future. Mr Angry PS. Hope all who have the same prob get it sorted soon. 👍🙄
22 Sep 2024 10:01 AM
It's disgusting how they have left us and sky a big company
Im just of the phone from sky support with the same issue.
The troubleshooting instructions given don't match what the website suggests.
The standby button needs to be held for 4-5 mins and not 20 seconds before any change on the tv occurred. After that and a software update everything was back up and running in about 15 mins.
22 Sep 2024 10:03 AM
@Law1987 wrote:I turned it off at the mains black screen all the time I done everything this is my second tv from sky it's a joke I keep being put on hold and getting cut off
This company is a big company and can't fix it within 3 days
Try this
Pull your plug out
press and hold the standby button on the bottom right of the tv as you look at it
put the plug back in while still holding the standby button
keep holding the standby button until the light at the front of the tv starts flashing
let standby button go
follow on screen prompts
I have 2 Sky Stream pucks. Since Friday I have had an issue with one of them. Firstly I only got the Sky start up screen.... so as per Sky help pages I've carried out a full reset on 4 occasions with the same result...
The activation code is shown and on Sky.com/activate when the code is entered it show as successfully added to my account however the screen still stays on the activation page.
I've just tried one suggested fix of turning if the puck remove the Ethernet cable and leave for 2 mins before putting the cable back in and turning on... get exactly the same result
I held on for 90mins yesterday for Sky support and they just told me to try and reset it again.
I can't understand what the issue is especially as I have one puck working fine.
any thoughts from anyone
@dzy82f wrote:I'm a newbie when it comes to posting to the Community. Please could you let me know how you include the original when responding to a post?
I've tried using an Ethernet connection but it doesn't work. As soon as I plug the puck back into my TV it goes into "flashing light" mode.
When the ethernet was plugged in did you run the reset procedure again, exactly as before?
For post replying;
Click on the arrow next to the like button, then click the double quote button just above where you type your posting. That will include the text of the post your responding to.
Or you can tag someone using the @ sign and their username
Like @dzy82f
22 Sep 2024 10:04 AM
Turning it off at the mains isn't going to fix it.
You need to carry out the recovery process as explained here: https://www.sky.com/help/articles/sky-glass-stream-wont-turn-on
22 Sep 2024 10:09 AM
The recovery process as stated does not work either??
22 Sep 2024 10:10 AM
If you have a problem reaching the https://sky.com/activate page, trying logging on the sky.com with an alternative / secondary email address that you use. It could take you to your 'Household Account' and you can then reach the activation page where you enter the six-figure numberic code generated on your TV screen. TBH I had no idea that I had a 'Household Account' so guess it was set up years ago.
22 Sep 2024 10:11 AM
I have followed all the advice and gone onto the links but the @Oops somethinf has gone wrong, please contact Sky customer services using this number" continues to appear. I am unable to put in the code provided on my TV and my sky glass TV still not able to link to my account and I am therefore unable to access anything on my TV. Ringing the help line is useless as the 'AI' recorded voice does not put you through to a human being. The customer service when needed most id asolutely diabolical. Telling peple to wait and be patient indefinitely is extremely frustrating to say the least. No commuication from Sky to the customer is also really annoying.
22 Sep 2024 10:13 AM
@Lewis1989 we just go straight to hold 7 an 9 for 2 seconds then u put your password in for your Internet thay is comes up saying error we have ever turned off all the power by the main fuse box reset the Internet box an still nothing so let's hope sky sort this out soon as it's past a joke now.
22 Sep 2024 10:14 AM
Again, how far do you get with the recovery process? Where does it stop?
22 Sep 2024 10:19 AM
Posted by a Superuser, not a Sky employee. Find out moreI have moved your post into this thread on the Glass issue as you'd posted on an old unconnected thread on the Sky Q board. Have you tried the advice in post 2 currently showing as the answer which has successfully sorted the problem for many customers?
22 Sep 2024 10:20 AM
Not a lot I assume
22 Sep 2024 10:21 AM
This may or may not prove helpful, but I've had problems resetting and repairing Sky Stream remotes before, and I learned an important lesson:
These remotes, once paired, connect via Bluetooth. But when unpaired, they rely on line of sight (I assume via infra-red).
I found I needed to have the remote quite close to the puck and pointing directly at the remote sensor in order to reset/re-pair it.
Worth a try if you weren't already aware of this.
