3454
Discussion topic: Sky Glass Power up Issues 19-9-24
This message was authored by Dave+1234567890 This message was authored by: Dave+1234567890
Re: Sky Glass Power up Issues 19-9-24
Anyone had problems recoding there sky q remote to the pucks word ok before the problem with sky glass
This message was authored by lettice This message was authored by: lettice
@dzy82f wrote:
Sorry, but this doesn't work
https://helpforum.sky.com/t5/Sky-Glass-Live/Sky-Glass-Power-up-Issues-19-9-24/m-p/4757859#M147519
This is the resolution that Sky have sent out and works.
It has worked for lots of Sky customers on here over the last three days to resolve the issue.
Follow the procedure exactly as described for in post 2 of this thread.
If you hit any problems during it like activation issues or pin issues, look at the other posts in this thread or come back here to be helped further.
Sky Community Superuser
Sky Stream (2 pucks), Sky Ultrafast + using Sky SR203 hub. Sky Protect kit tester.
This message was authored by Campervan20 This message was authored by: Campervan20
My sky won’t start up keeps saying no signal then turns itself of
Have sky with mini box puck comes on to saying no signal then turns it of
@dzy82f wrote:
I used an ethernet connection to force a software upgrade but I can't get a white light when I try to power on or use the home button. Interestingly, the remote will switch the TV on but not the puck.
Can you expand your query  a bit further. not sure what you have so far tried?
Have you tried the following;
Follow the procedure exactly as described for Sky Stream in post 2 of this thread, flagged as the Answer post from Sky.
This message was authored by Operator2024 This message was authored by: Operator2024
I have exactly the same issue , been on the phone waiting to speak to someone for over 2 hours today.  It's seriously not good enough.  Even the voucher they used for the sky store as a gift for the issues has an error 😡
This message was authored by TD79 This message was authored by: TD79
I have followed the procedure exactly as stated, word for word.
I get to the link your account, go to sky...activate,
Code accepted but glass still stuck on the same page.
Any ideas?
This message was authored by Peter261 This message was authored by: Peter261
My glass tv has frozen
My glass tv has frozen after a reboot have had nothing for 2 days can anyone help
This has not worked sadly
Re: Puk no signal
Have been trying but just stays white, then back to no signal
This message was authored by Fothergill1 This message was authored by: Fothergill1
@Dave+1234567890  I use a Sky Q remote as a secondary remote but since the update a couple of months ago you can no longer pair the Q remote to Glass/Stream with bluetooth.  It only works in IR mode.
Since the recent Sky outage the Sky Q remote still works perfectly well in IR mode.
If my post has solved your issue please mark as an "Answer"
This message was authored by kharis This message was authored by: kharis
Have followed your instructions several times and it still does not work.  Tried phonecalling for assistance but after 35mins got dumped off. Is this problem EVER going to be SOLVED. Gutted I ever bothered with Sky Glass.
This message was authored by Leestenning69 This message was authored by: Leestenning69
Re: My sky won’t start up keeps saying no signal then turns itself of
My sky puc comes on then switch's off please can sky sort this out
This is the resolution that works, that you have to do.
Follow the procedure exactly as described in post 2 of this thread, flagged as the Answer post from Sky.
If you have any issue with activation during the process or entering the pin do the following;
Activation problems:
Try refreshing your browser cache or try the activate link in another browser or device.
Before clicking on the activate link, log in to your MySky account first.
Also, try this alternative link;
Make sure you have logged into your Mysky account in your browser before trying.
https://www.sky.com/productsettings/streaming-tv/activate
Also, you could try using a mobile phone, not connected to your home broadband.
Pin problems:
When at the pin stage and it fails.
Remove the power from your Puck or Sky Glass TV,  leave off for a few minutes and repower.
It will continue, follow the instructions.
This has worked for many having a pin issue
This message was authored by Prossi14 This message was authored by: Prossi14
Sky puck light just flashing
The puck is flashing white, sky wording comes on screen for a few seconds then goes black and the puck goes to solid white. Have done the reset and nothing will get it to go further than white sky letters on black background.
Same here , did you get a resolution
