3359
Discussion topic: Sky Glass Power up Issues 19-9-24
This message was authored by B_har This message was authored by: B_har
Re: Linking to sky account
Exactly the same with me
This message was authored by Shannon87 This message was authored by: Shannon87
Re: Sky Glass Power up Issues 19-9-24
I'm on day number 3 now of no TV, keep getting to the stage of 'you're now connected' and then the TV just freezes
This message was authored by Fothergill1 This message was authored by: Fothergill1
Thank you @horace It's good to know that some people appreciate the effort 👍
Unlike the anonymous poster who said amongst other things (excuse the cut & paste) "I am writing this to help others that may be having this issue as the self-described superSkynerds, or whatever they are called, are gaslighting the lot of you with their inane and self-important posts."
I was somewhat disheartened after reading that and haven't helped anyone on this thread since. But seeing you post has encouraged me again 😀
If my post has solved your issue please mark as an "Answer"
This message was authored by lettice This message was authored by: lettice
@Jackie114 wrote:
This doesn't even work, there is no red light on the sky TV at all there is power because the light on the microphone button is on but there is no red light and nothing coming on, so it won't even let you reset it on this stage, this is pathetic. Why can sky control if the TV comes on at all anyway? We can't even connect devices to hdmi and play anything.
@Jporch316
As a Sky Glass owner (I'm only have pucks), is this red light more of an issue for this customer?
Sky Community Superuser
Sky Stream (2 pucks), Sky Ultrafast + using Sky SR203 hub. Sky Protect kit tester.
This message was authored by Pat+Maxim This message was authored by: Pat+Maxim
Re: Sky glass won’t connect to broadband
I have not been able to get sky glass to load for two days and tried all the fixes. No one will speak to me Sky I have waited over 2hours in a queue twice. This Service is awful.
This message was authored by Kyle26 This message was authored by: Kyle26
Sky
I have three WiFi and is working on my fire tv and phone but my sky pick won't connect I've tried to reset the puck and my WiFi and I know the WiFi ain't the problem anyone else dealing with this
This message was authored by Tinae This message was authored by: Tinae
Re: Sky Glass TV won’t turn on
Hi my sky glass won't turn on, I've turned of off and held the side button reset the remote left it but still nothing ? Anyone ?
This message was authored by Jporch316 This message was authored by: Jporch316
@lettice wrote:
@Jporch316
Hi had a red light on one of my sets but no lights on the other. Both of them worked following the recovery process
the set with no lights took a little while longer holding the reset button before the flashing led appeared
others have reported pulling the plug for a while forced the red light on
43inch and 55 inch Sky Glass & 3 Pucks on virgin media M350 hub 5x. 4 x sky mobile sims. Pretend guitar aficionado .. rock on!
@Jporch316 wrote:
@lettice wrote:
@Jporch316
@Jackie114
Can you try the above, hope it helps you.
This message was authored by Laura249 This message was authored by: Laura249
Sky Glass account log in
Having issues with the link your account stage on sky glass. When we enter the code on the sky.com/activate
Site it says oops there is a problem.
This message was authored by Lesley07 This message was authored by: Lesley07
I am trying the mobile hotspot and it isn't connecting to the internet although it is connecting to my iPhone any suggestions please
This message was authored by horace This message was authored by: horace
@Fothergill1
Funnily enough, it was that very post that made me realise that you guys weren't getting the praise you deserve.
In any case, there's really no excuse for rudeness.
Keep up the good work, it is indeed appreciated.
This message was authored by Operator2024 This message was authored by: Operator2024
Puk no signal
One of our puk's has had no signal since Thursday.  We thought totally unrelated to the Sky glass issues and a coincidence.  As the main Sky glass is working as is the other puk.  Sky have no idea either and the recovery process is not working.  Anyone any ideas please.  Many thanks.
Glass tv not working
My sky glass will not turn on - tried to reset it - turned it off, reset the remote but nothing but a flashing red light been like it for nearly 2 days now
Trying moving the remote closer -
when reset it defaults to infa red and needs to be really
close to operate the tv
