4306
Discussion topic: Sky Glass Power up Issues 19-9-24
Locked
This message was authored by Fothergill1 This message was authored by: Fothergill1
Re: Where do you put the activation code in? After resetting my tv?
@Kirby+Grip wrote:
@Louisa801
I'm absolutely drained tried everything live chat sent me to setting done all instructions then they were gone off line. Have been trying all day telephone, linking etc etc at my wits end
@Kirby+Grip It's not clear from your post so apologies if you have already done so but have you tried the recovery procedure HERE which Sky have advised subscribers to carry out?  It worked for me.
If my post has solved your issue please mark as an "Answer"
This message was authored by DizzyShay This message was authored by: DizzyShay
Re: Sky Glass Power up Issues 19-9-24
I've got mine working unplug the cable from the back of the box
Hold down the on/off button on the bottom of the device and plug the cable back in
After 20 seconds the light will flash different colors
And it device will download a update and be back into factory settings
Sign back in and away you go
This message was authored by TT21 This message was authored by: TT21
Re: Stream Pin issues
Mine was exactly the same. Put the puck on standby leave it for at least 3 minutes put it back on again. This has just worked for me
This message was authored by PMS123 This message was authored by: PMS123
Re: Sky puck power up issues
When I eventually managed to speak to someone this morning after hanging on for over an hour I was told that I would be entitled to reimbursement for as long as my sky stream was unavailable as it was due to a sky issue/outage. No idea if calls are recorded or not for quality and training purposes etc etc
This message was authored by Kate000123 This message was authored by: Kate000123
I have re-booted my sky glass but now in set up mode it will not connect to the internet. My connection is fine (all other devices are connected) but it looks like the TV just can't find the wi-fi connection any more - the IP address seems to have re-set to 0000.
Please can anyone advise if they are having the same issue post re-set ?
This message was authored by Leo-lion123 This message was authored by: Leo-lion123
Can you tell me what this has to do with a sky puck flashing continusily when your router is working fine many people on here having this problem what has this got to do with engineers working to fix the problem this is the puck not working nothing to do with engineers fixing problem to your router
This message was authored by Chris408 This message was authored by: Chris408
No Sky Glass TV since Thursday at 16.30, it's now 20.00 Friday. This is unacceptable Sky.
This message was authored by Bugs1 This message was authored by: Bugs1
My q box white light is flashing and can’t access my TV
Can't see any live TV and white light on q box keeps flashing.
there is no customer care support online available.
This message was authored by Dazzasky This message was authored by: Dazzasky
Re: Sky tv
@Tasha39-xxx wrote:
It's so annoying u pay for these things and they don't work , all day today no sky tv
Look at the answer in this thread and you should be able to fix
https://helpforum.sky.com/t5/Sky-Glass-Live/Sky-Glass-Power-up-Issues-19-9-24/m-p/4759288#U4759288
@Tasha39-xxx
This message was authored by welshy3061985 This message was authored by: welshy3061985
Re: Pin
I have the same issue after trying the suggested reset steps.
This message was authored by NA21 This message was authored by: NA21
I have followed the official instructions obtained from the link posted here and got an error on software update and instructions says to ring up customer services... like nothing better to do .... if its a software update then normally it should go through with no issues why ring sky?
Seems like someone in IT has pushed software update with no testing or plan...
Awful!
This message was authored by MissWendy This message was authored by: MissWendy
Re: Puck keeps turning off and back on
My sky glass tv and my puck in bedroom have not worked for last 30 hours and sky internet is so rubbish cannot get wifi signal to other tv. Any suggestions as depressing with sudden realisation of how much I depend on sky for tv and getting netflix etc which will be changed shortly. Thanks.
My understanding is it's not an internet problem but a software update issue.
Sounds like the receipt Microsoft debacle
Sorry I can't answer that.  I'm a frustrated user too not a sky engineer. All I can tell you is that this worked for me. If it helps mine did exactly the same this but is now working by putting the puck into standby
This message was authored by Cammy02 This message was authored by: Cammy02
Re: Sky Glass Power up Issues 19-9-2Where are these LED lights?
@GD1 wrote:
Thread title created to reflect current issue
Locked
