43
This discussion topic has been answered Discussion topic: Sky Glass Air turns itself on from standby for a few seconds
This message was authored by: gr1340
I have the glass air and for some reason it keeps turning on for a few seconds then turns off again.
The screen is black and the backlight is on but nothing else appears and it is only for a couple of seconds.
I have just unplugged it for a couple of minutes to see that helps but just wondered if anyone else had the same issue.
Moderator note: subject of thread updated to better reflect the conversation
This message was authored by: KevNewMedia Answer
Re: Sky Glass Air turns itself on from standby for a few seconds
Posted by a Sky employee
We've escalated this problem to our support teams @gr1340 and when we have more information, we'll update your thread.
I'm going to mark this post as the current answer, so that everyone has the most up-to-date information.
Workaround:
Some people have found by switching off the mic on the TV, this seems to resolve the issue. We continue to investigate and provide a fix, however if this is troublesome for you, this may help to stop the problem temporarily. If you do this, you can still use voice control through your remote control.
Kev
Community Manager
Re: Sky Glass Air turns on then off every 30 minutes
@gr1340 Is motion activation turned off in the settings?
I have a vague memory of someone saying it did this after an update. Is it happening often?
Avatar for gr1340
The air doesn't have motion activation like the normal glass
@gr1340 Fair enough. Wasn't aware of that.
Is this turning on and off happening frequently though? I remember on my Gen One that it would do the same from time to time but it would only be once, then not happen again for a while.
This message was authored by: Jporch316
Hi @gr1340
I have escalated your post to the sky community online support team
plrsse lookout for an invitation to chat with them
This message was authored by: Morphi
Mine does it very occasionally several times in the last week with 2x different TV's) there is usually a freeze just before.
Avatar for gr1340
Re: Sky Glass Air turns black every 30 minutes
Whoever updated the subject has got it wrong.
The TV is in standby and it turns ON for a few seconds. The screen is black but the backlight is on, after a few seconds, it turns OFF and back into standby.
Hi @gr1340
Welcome to the Sky Community, and thanks for sharing your post.
It was myself who amended the title, based on the information provided initially. I hadn't realised that the TV was on standby when this happens, so I've modified the title again 👍
Kev
Community Manager
Workaround:
Kev
Community Manager
Hi @gr1340
Can I ask how often this is happening?
Kev
Community Manager
Avatar for gr1340
Morning.
It happens at least every hour, I initially thought it was HDMI CEC related as it was connected to my AVR but I disconnected that a few days ago and it still happens.
@gr1340 wrote:
Morning.
Hi @gr1340
Can you advise if you see any on-screen messages when this happens?
To enable us to understand the problem better, can you test switching off this feature and let me know how you get on?
Kev
Community Manager
Avatar for gr1340
No messages, just a completely blank screen for a couple of seconds.
I will try turning off voice control and report back.
This message was authored by: DarrenB7
We had this happening last night on our Sky Glass Air, screen would flash really bright (thought it was lightening outside initially) then screen backlight would turn on for about a second (nothing on the screen) then would go off again. Seemed to do it every 5 minutes or so. Restarting device did not solve it so powered off in the end. On software build version QS038.003.00P.
have turned the microphone off and see how it is tonight, suspect won't notice it again until room is dark.
Morning @gr1340 @DarrenB7
Have you seen the issue since switching that feature off?
Kev
Community Manager
Answered - Go to Answer
