Discussion topic: Power-up error message
This message was authored by: RaiJay
 Randomly got this message and tried to power on and off multiple times, much to my disappointment.  Anyone know how to fix this?
Re: Power-up error message
@RaiJay that could be caused when the TV isn't connected to the internet.
Try unplugging your router for a few minutes
Try unplugging your TV for a few minutes
How is your TV connected to the internet, it is possible to try connecting it via ethernet cable ( if its connected via WIfi) and then unplug the TV for a couple of minutes and see if that helps get it further.
Avatar for RaiJay
Hi,
Thank you for your response.
It was set up with WiFi, but as I've recently changed providers, I put the new network key in and now that's what is showing and can't get back to home to do anything.
So that is showing all the signs of it not connecting to your WiFi in that case. I'd suggest trying connecting via Ethernet if possible to at least get it booted and then you can try the WiFi setup again.
