Discussion topic: Pin issues and subscription
This message was authored by: Totalwar2
Pin issues and subscription Having both issues at the moment.I put in the correct pin but says I have not reset pin and still says the same.I also having issues with subscription saying don't have the correct one to watch this channel.it's affecting various channels including Sky news.Anyone else having theses issues.
Sky Glass Generation 1 and Sky Glass Generation 2 Sky Moblie SKY BRING BACK NEVER MISS.
Re: Pin issues and subscription
Hi @Totalwar2 try restarting in the first instance to see if that resolves anything. If not leave it unplugged for a few mins and then try again.
  1. Go to Settings
  2. System management
  3. Resets & updates
  4. Restart device
There was some issues yesterday evening on voice control and playlists and it could be that there's still issue's and you're being affected by this.
Avatar for Totalwar2
Level 7 icon
Done what you suggested and it updated to the latest software update.Hopefully will fix some of the bugs that I getting at the moment
Thanks for giving your time and for your help.
