709
This discussion topic is read only This discussion topic has been answered Discussion topic: Last few days, technical fault with channel, disney plus etc works.
Locked
Re: Last few days, technical fault with channel, disney plus etc works.
@wsimm I did say I had doubts a new TV would sort the issue out. I'm sorry to be proven correct.
This message was authored by: Nic2910
Sky glass
Hi
ive got a sky glass tv which is about
two years old. It has started to need
resting as it locks up with a message
"waiting for program to load"
it's connected via a 500mb Ethernet connection which I've performed a speed test on which is fine.
sometimes the live program goes blank but the menu's will still work fine, if I change channels sometimes it restores itself and sometimes needs a power cycle to cure the problem.
any help much appreciated
This message was authored by: Blue+Dog
Re: Sky glass
@Nic2910 it's a widespread software problem affecting Gen 1 and Gen 2 Sky Glass. Sky are working on a fix, allegedly.
This message was authored by: peter-marlow+1966
I have been monitoring  both my 55inch sky glass tvs gen 1 and gen 2, i  still  have not had any  of  the problems  mentioned  in the discussion, i am on full  fibre  broadband gigafast 900mps with sky to, puck also working  fine
P c marlow
This message was authored by: thereaduckofdeath
And the effing self-playing Amazon ads while using the HDMI is back.
FIX THIS GARBAGE, SKY!!!!!!!!!!!!!!!!!!!!!! JUST EFFING FIX IT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
@peter-marlow+1966  Good that you haven't experienced the pain - I too have gigabit broadband, but even with hard wiring with Ethernet the problem is there. Over two weeks of repeated resets after 4 years with no issues.
Both of my tvs are  also connected  by ethernet cables
P c marlow
I have just finished  watching  star wars  a new hope on disney plus, as its  star wars day, may the 4th be with you
P c marlow
@peter-marlow+1966  Yes. Apps are unaffected by the issue - just tv channels. My point re the Ethernet was that it's not a WiFi speed/ stability issue - it's a software problem affecting many people with Gen 1 and 2 sets. It's real - Sky have acknowledged the issue and say they're working on a patch. Hopefully that materialises soon. Using my puck tv for now.
This message was authored by: DMK
This has been an issue for at least a month lets hope they fix it soon.
This message was authored by: neildark
Re: Programme loading
Filled that in yesterday
This message was authored by: Cocoalex
Sky you are not helping. Just fix the problem. Send a bloody engineer **bleep**
An engineer can't fix a software issue.
So who or what can be done? I cannot watch anything now.
I wish Sky was with us. We are helpless. I want a massive refund for the inconvenience
Locked
Answered - Go to Answer
