709
This discussion topic is read only This discussion topic has been answered Discussion topic: Last few days, technical fault with channel, disney plus etc works.
Locked
This message was authored by: TimBL
Re: Last few days, technical fault with channel, disney plus etc works.
On Thursday evening I turned the WiFi connection off, so it would solely connect via Ethernet, and rebooted the Glass. This seemed to work OK, as for the remainder of the evening it did not glitch. However this afternoon and evening it's started doing it again.
I rebooted it several times, and each time about 4-5 minutes in it goes black but the audio remains.
So I bit the bullet and did a factory reset. It wasn't as painful as I feared and soon had the Glass up and running again the only things I had to do was log in to the apps again. So far so good, but far from ideal.
@Chloe-W22 we have a video we have taken of the occasions where the Glass glitches and the picture disappears but the sound remains.
Something like that would be useful for SKY to see what we are experiencing.
This message was authored by: Jporch316
Re: Sky Glass no live TV but streaming services work fine
@bobbob1982 wrote:
I've recently been getting exactly the same error come up.
Very frustrating.
@bobbob1982  see below main thread for your issue which began mid April
https://helpforum.sky.com/t5/Sky-Glass-Live/Last-few-days-technical-fault-with-channel-disney-plus-e...
@TimBL You may find things are okay for a few days but then the problem will start again. That's been my experience after a factory reset.
This message was authored by: Katie-
Screen keeps going black but still have sound
Screen keeps going blank but we still have sound. I have to keep turning the TV off at the wall numerous times throughout any one episode. Live tv won't load and when I try to load my apps I brings up a technical fault message. This is proving frustrating. When I've tried to follow the links on my sky it says there is no fault. Please could someone advise. Thanks
This message was authored by: pete1986andrew
Sky glass Gen 2 problems
Hi guys, I'm still having trouble with my sky glass Gen 2, all the same problems as before with the black screen etc. Please can you put this one in the main feed of the black screen problems. I've also like to add but some of the apps are not working as well. I'm also getting sound from other apps and not pictures so it's not just on the TV but I'm having problems. It's on the apps as well. Hopefully sky will find a fix for this soon cuz I'm sure we are all getting pretty annoyed with the amount of money we pay and they still haven't found the fix. Thanks for your help on here guys
Re: Screen keeps going black but still have sound
Have moved your posting into this ongoing issue thread.
Read the answered post within this thread from Sky on the issue and fill out the form as mentioned in the answered post.
Sky are investigating and we as Superusers are keeping them aware of many others having the issue
Re: Sky glass Gen 2 problems
@lettice
please merge with main thread
@pete1986andrew
As above
Sky are investigating and we as Superusers are keeping them aware of many others having the issue.
This message was authored by: Jolly-olly
I cannot believe this. I have opened the form ready to complete, turned on my Sky Glass and for the first time in over a week I haven't got the issue. Fingers crossed.
Haha, that's hilarious.
Magic, coincidence or the form having some kind of AI code 😀
Lets hope it continues fine for you.
This message was authored by: Stevo1070
Re: TV glitch
If my screen goes black whilst watching something, I have found that I can just change channels until I find one that's working, then return to the one I was watching.
This message was authored by: neildark
I have exactly the same thing, was advised to upgrade to the white router, still same problem. Paying for a package i can't use and an upgrade that i didn't need what a wonderful service 🫠
This message was authored by: DMK
I have the same issue when turning on the TV in the mornings, all is fine for the first 5 minutes, but then the screen goes Black, but I have sound, if I change channel, I get the waiting for program to load. I have tried everything, but it's still the same issue. It happens every 5 minutes for the first 2 hours, I am turning the TV off and on again at the plug every 5 minutes ( which, being disabled, is not easy ). To say that I am annoyed is an understatement; if they don't sort it soon, it's GONE.
Locked
Answered - Go to Answer
