4
This discussion topic has been answered Discussion topic: I've made an order but I need a TV as I haven't one help
This message was authored by: Matty55
I have made an order for sky for stream but not noting I don't have a TV computer just a mobile phone have I done wrong
This message was authored by: BenJoBanjo Answer
Re: I've made an order but I need a TV as I haven't one help
You should have ordered a NOW subscription instead. Absolutely pointless getting a Stream puck without anything to attach it to.
Avatar for Matty55
I need a TV to go with my order
I've placed an order but I have no TV
Re: I need a TV to go with my order
@Matty55  The question is why have you ordered SkyStream if you don't have a TV to watch it on?
If you need a TV you have 2 options buy a Smart TV from ant retailer or you need to purchase Sky Glass, if it's Sky Glass you want you will need to call Sky to cancel your current order and place one for Sky Glass.  If you fail the credit check you may need to purchase outright.
@Matty55
If you really want to, you can keep the Stream puck (which will be 'activated' automatically) and then use the Sky Go app on your mobile.
