Discussion topic: I have a sky puck and keep losing connection
This message was authored by Mark335 This message was authored by: Mark335
I have a sky glass tv and sky pick and I keep losing connection to my wifi with the puck . It is happening more and more often.
This message was authored by Fothergill1 This message was authored by: Fothergill1
Re: I have a sky puck and keep losing connection
Hi @Mark335 and welcome to the forum.  Your puck might just be losing the network connection when it is in standby so go into the Settings > Start up & standby menu and make sure that the option for "Networked standby mode" to ON.  I would also turn OFF the overnight power saving.
If my post has solved your issue please mark as an "Answer"
This message was authored by Mister_Dalek This message was authored by: Mister_Dalek
The room in which you have your puck needs to have a fast and stable broadband signal at all times in order to function.
If the Wifi signal strength is not high enough then you need to move your puck or your router or install a Wi-Fi mesh system or use power line adapters in order to pass a broadband signal of sufficient quality to the puck.
This message was authored by BrendanH1 This message was authored by: BrendanH1
Which settings? SkyTV .. It wont swith on .. continous flashing
