Discussion topic: How can I connect my sky glass to my Logitech digital surround sound system?
This message was authored by: CornichePasty24
The amp/bass box does not have an HDMI connection.
This message was authored by: Mister_Dalek
Re: How can I connect my sky glass to my Logitech digital surround sound system?
Then you'll need an eARC audio extractor which can convert the output from HDMI 2 on Sky Glass to optical. You will need to source such a device yourself and purchase it at additional cost.
Avatar for CornichePasty24
Thanks. I will research the box.
This message was authored by: KateWinslet
To connect your Sky Glass to your Logitech digital surround sound system without HDMI, check if the sound system has an optical or AUX input. You can use an optical (Toslink) cable from the TV’s optical out port to the surround sound system, or use an AUX cable if supported. This should allow you to route the audio through your sound system.
This is nonsense.
Sky Glass does not have an optical output or an analogue AUX output.
Hi @Mister_Dalek
I have treid an ESCOO 4k 120 Hz extractor with no success - then I found that the Sky Glass is 60Hz.  So I tried an EZCOO 4k @ 60 Hz extractor  with no success either.  Any ideas? Im sure the Logiteck Z906
5.1 systemc is compatible with the right interface.
CP
