Discussion topic: How do i connect my PS5 to Sky Glass?
Message posted on 19 Jan 2024 03:51 PM
Woth my previous tv, I list selected "source" on the remote, and then chose the hdmi port number that the ps5 was connected to the tv, by.
I have connected the ps5 to the sky glass tv via a hdmi cable and turned both on but I can't find an option to find the hdmi port it is connected to.
Anyone else had an issue?
Message posted on 19 Jan 2024 03:55 PM
Re: How do i connect my PS5 to Sky Glass?
@Benkeirle wrote:Woth my previous tv, I list selected "source" on the remote, and then chose the hdmi port number that the ps5 was connected to the tv, by.
Try rebooting your Glass TV. Turn it off at the wall for a minute then power it back on and see if the HDMI inputs are accessible.
Message posted on 19 Jan 2024 04:01 PM
Should be under Home - Apps and inputs
Some Playstation users have had more sucess with an HDMI 2.1 ('8K') cable, but don't pay more than £10 for one if you want to try this.
Message posted on 19 Jan 2024 04:53 PM
Certified 2.1 cables may cost as much as £12😉
