Discussion topic: Check Device Power Error
Message posted on 25 Jun 2024 10:22 PM
Hi,
My Sky TV box is not connecting to my Samsung TV, keeps coming up with a check device power message.
Gone through trouble shooting on the TV, tried different HDMI cables. Seems like its an error with the Sky box not correctly turning on, or something weird the TV is not letting the box turn on.
Looking for any suggestions
Message posted on 25 Jun 2024 10:53 PM
Re: Check Device Power Error
@ChrisCarr you have posted in the Glass forum which is for the TV. When you say TV box, do you have Sky Stream or Sky Q? It would also be good to understand if this is a new install or of it's just stopped working?
If it is a Sky stream puck, could you try it on another TV at all? This could help rule out the TV. Remember we are fellow subscribers on the forum and have no idea what your setup is unless you are able to provide us with as much information as possible.
MikeAlanR
Message posted on 26 Jun 2024 01:38 PM
Thanks,
New install for the sky stream puck
TV is new Samsung qe55s90ca
Kind regards
Message posted on 26 Jun 2024 04:05 PM
@ChrisCarr wrote:Thanks,
Kind regards
Does the white light come on on the front of the puck when you power it on? Make sure the HDMI cable is firmly connected.
