Discussion topic: Adding a sky TV in addition to my existing sky package
This message was authored by: Jcp57
I am an existing Sky customer with Sky TV and muti room Sky Q. I want to add a Sky TV to my adress to use in a different annexe to my house can I do this? The helpline said I cant have two different accounts at same address, but If i add a Tv to my existing package does this still work?
Re: Adding a sky TV in addition to my existing sky package
@Jcp57  No you can't have sky glass and sky Q on the same account it's either one or the other
the only way round would be if the annexed building is classed as a separate address by having it's own postal address and water/gas/electric supply/billing
Avatar for Jcp57
Thanks as the annexe is 30m away sky Q want work, what about acessing Sky via sky now in the annexe would that work? The annexe does have a separate water and electricity supply and account but the annex doesnt have a separate address
@Jcp57  Now tv will work assuming you have an internet connection that reaches to the annex
@Jcp57 Sky Go would work if you have (or can get), a suitable device such as a PS4, PS5, Xbox One, Xbox Series S/X or Apple TV, have a multiroom subscription and can get a network connection in the annexe.
LG B6 OLED 55” | LG UP75 LCD 43” | sky Q | sky Q Mini | SONOS Beam 2 | Apple TV 4K | EE Full Works FTTC
Avatar for Jcp57
Thanks really helpful, I do have a separate internet service to the annexe so that might be my only option
@Jcp57the Apple TV box is a good choice ... you can even access IP broadcast channels using the TV Launcher app's epg via the Sky GO app and other apps😉
This message was authored by: Jporch316
If the annexe is the same billing address as your main house then you could get sky stream whole home.
sky may pick up on the separate ip adressses but I believe a previous poster had sky stream multi room running in "one" property but one on his personal email account and one on his work internet
@Jporch316  no that won't work you can't have stream/glass at the same billing address as sky Q
Sorry ... to be more clear I meant instead of Q. One stream unit in the main house and one stream unit in the annexe
