Discussion topic: Can’t connect sky glass with Ethernet cable
This message was authored by: Trace647
I'm trying to connect with an Ethernet cable as WiFi keeps dropping out. It gets as far as getting up address and then says it can't find it
Re: Can’t connect sky glass with Ethernet cable
@Trace647  Try restarting your hub , also make sure your doing a network reset in the Glass TV settings menu.
Avatar for Trace647
Hi, thanks for your answer. I have reset everything numerous times and that hasn't worked
This message was authored by: Jporch316
Try swapping the port you are plugging into on the router
also try a different ethernet cable
Avatar for Trace647
I have tried this with no sucess. It never gets past acquiring ip address.
Have you rebooted your router ?
Avatar for Trace647
Yes, several times and I have rebooted the glass too
Have you tried a different ethernet cable or a different port on your router ?
Avatar for Trace647
Yes both. Still doesn't work
