7
Discussion topic: Can Sky Glass work using a IR remote?
This message was authored by Greshr This message was authored by: Greshr
Hi,
I work with people who are profoundly disabled and can't use a conventional TV remote or Voice. The solution for these patients is to record the IR output from a TV remote and playback each code on a button press. The most common product we use is Gridpads running Grid 3.
My question is like the Sky Q  can you control Sky Glass using IR instead of Bluetooth or other Radio?
Thanks in advance
Greshr
This message was authored by Mark39 This message was authored by: Mark39 Answer
Re: Can Sky Glass work using a IR remote?
Yes, you can. Glass can be controlled in both IR and Bluetooth modes. I have no knowledge of Grid pads, though, and can't speak for how well it will work with it.
Greshr
Thank you, Mark.
One more question; can you use a Sky Q remote or do you need to unpair the Sky Glass remote? (if its the latter how do you do that)
A Sky Q remote will work, but I'd have to test later whether you can use a Sky Q remote in IR mode while Glass is paired to a Glass remote for Bluetooth mode (which I think is what you're asking).
Or another Community member here may know.
Greshr
Yeah, I'm after that sort of thing. I really appreciate your help, I don't have access to a Sky Glass and all I have is a Sky Q remote set to IR mode. In my experience with Sky Q is that the box will work with both Bluetooth and IR at the same time.
Works fine without unpairing the Glass remote.
I didn't try all the buttons, but the major functions work. I don't know if the Q remote's record button is equivalent to the Glass remote's add to Playlist function (didn't try it). The Q remote's volume/,mute buttons won't work with Glass as there's no code to pair with the Glass TV.
This message was authored by Cliffton This message was authored by: Cliffton
Can the Puck for Sky Glass be controlled via an infrared remote control?
I haven't tested all functions, but the main functions, yes.
On average, new discussions are replied to by our users within 7 hours
