310
This discussion topic is read only This discussion topic has been answered Discussion topic: Vue Cinema Tickets not showing
Locked
This message was authored by: Sally1997
Re: Vue Cinema Tickets not showing
GENIUS !!!! Thank you so much 😊xx
@Sally1997 No problem. I do think Sky could have done more to make customers aware that you can scroll the tiles horizontally, like putting direction arrows on the tile/under it like the top part of the screen.
Not very user friendly, like so much of Sky's set up.
You have been so helpful !
I can't thank you enough x
This message was authored by: gooner173
You are very welcome!
This message was authored by: SC1960
Vue codes disappeared
Where have the codes gone for the sky cinema tickets?
Re: Vue codes disappeared
@SC1960
Go to the VIP section then scroll down to "Rewards for you" then scroll to the left until you see them.
This message was authored by: HenessyLake
I am swiping left but out of my 7 reward tiles none are for vue. Dont have broadband but do have sky and sky cinema so I should have them but they are not on the app so don't have the broadband tile on my app.
My only rewards are prizes to enter.
@HenessyLake @SC1960 Make sure you do this exactly:
1. Open the My Sky app and select the VIP tab in the bottom right. The star icon will turn into a solid blue star.
2. Scroll down to the Rewards For You section.
3. Place your finger on the first tile and scroll to the left. The Vue tickets will be the fourth or fifth tile:
This message was authored by: Malc2
I had them in may but cannot find them for june
@Malc2 See my post immediately above yours for how to find them.
Thank you, found them now
This message was authored by: PeterBrindle
Yes I am having the same problem
Thanks that worked
This message was authored by: fgsysbt
No mine aren't there either.
@fgsysbt They are. See my earlier reply (post 203) for how to find them.
Locked
Answered - Go to Answer
