310
This discussion topic is read only This discussion topic has been answered Discussion topic: Vue Cinema Tickets not showing
Locked
This message was authored by: chrish57
Re: Vue Cinema Tickets not showing
No tile there for me for June 2025. Always been visible in previous months.
@chrish57 See my earlier step by step guide as to where to find them.
It is there @chrish57 so in the VIP section scroll down to the "rewards for you" section then keep moving the tiles to the left until you see it.
This message was authored by: MaggieWagstaff
vue cinema tickets
My free two vue cinema tickets are not showing to download
Re: vue cinema tickets
@MaggieWagstaff
They have been moved so go to the VIP section then scroll down to "Rewards for you" then scroll to the left until you see them.
This message was authored by: MargaretM1
Re: I cannot see vue cinema tickets on my app
Same for me. None appeared in May and I can't see any for June either.
@MargaretM1
They have been moved so go to the VIP section then scroll down to "Rewards for you" and then scroll left on the tiles until you see the Cinema tickets tile.
This message was authored by: Whu63
Re: Vue cinema tickets
Having same problem
@Whu63
See the post above yours as it explains how to locate them.
This message was authored by: gooner173
Re: VIP VUE TICKETS
Thank you!
  • I couldn't find the codes but yes go to broadband and swipe and they are there
This message was authored by: HenessyLake
I have sky vip silver and my vue tickets are not showing up anywhere. I have looked all over the app, don't have broadband with them so that option doesn't show up for me where others have been able to access it but I have always been able to access my vue tickets until this month.
Does the tile vanish if the tickets have already been snapped up as I know they have a limited amount or is silver vip not allowed vue tickets now?
Go to your sky vip. On the exclusive offers on  broadband swipe left twice .The view ticket/ codes are there.
I had same trouble on an earlier post somebody explained this.
This message was authored by: Sally1997
Thank you for response but they are no longer there.
i thought maybe they had reached the quota available for May as it was the end of the month but i have logged in the morning and the option is definitely not there 😞
Thank you, I have manged to find them
@Sally1997 Follow these steps:
1. Open the My Sky app and click on the VIP tab button in the bottom right. The star will then be highlighted in solid blue.
2. Scroll down to the Rewards for You section.
3. On the first tile put your finger on it and scroll to the left. The Vue tickets will be the fourth or fifth tile along (tickets are not limited but are only available if you're a Sky Cinema subscriber):
Locked
Answered - Go to Answer
