310
This discussion topic is read only This discussion topic has been answered Discussion topic: Vue Cinema Tickets not showing
Locked
This message was authored by: Char1813
Re: Vue Cinema Tickets not showing
I have done all this and the still arnt on my sky app ... can't talk to anyone on chat bot ... is there a delay in them.being posted
Have you found it as I can find it anywhere in vip please
I have done all of that and still not on my app have never had an issue before but wanted to use them and they arnt there at all please help
@Char1813 Mine were available on 1 June as they should have been.
You could try and uninstall and reinstall of the My Sky app then try the following:
1. Open the My Sky app and select the VIP tab (the blue star in the screenshot below)
2. Scroll down to the Rewards for You section:
3. Put your finger on the Sky Broadband tile and scroll to the left. The Vue tile will be the fourth or fifth one along:
So you have gone to the VIP section @Char1813 and scrolled down to "rewards for you" and then moved the tiles to the left ?
Thank you I have done that and its still not there
  • I dont have rewards for you ... I have rewards near you ... and yes have uniatalled and reinstalled a few times now
@Char1813 Try doing it exactly how I explain. They are there and you do have a Rewards For You - see my screenshots.
I can't explain it any clearer. Others have followed my instructions exactly and found them. (Just checking - you are subscribed to Sky Cinema still?)
For those having difficulty finding them:
1. Open the My Sky app and click on the VIP tab in the bottom right - the star will be solid blue if you do this.
3. Put your finger on the Sky Broadband tile, hold and scroll left. The Vue tickets are the fourth or fifth tile as you scroll horizontally:
I have just found them thank you for your help
This message was authored by: Jbirnie
Vue cinema tickets
The June Myvue ticket codes are not showing app despite still having sky cinema
Re: Vue cinema tickets
Have moved your post here to the ongoing discussion.
View the answered post in here for how to find the Sky Cinema Vue tickets
@Jbirnie See my earlier reply for step by step instructions on how to find them. They are, just well hidden by Sky!
This message was authored by: Gosspeter
Re: Sky vue cinema tickets missing
That works perfectly
This message was authored by: Sam373
Hi I have used them before but for June they are not appearing, what can I do?
Finally found them but had to keep going in and out as wasn't showing. I use them all the time so it wasn't like I didn't k is where to find them
Locked
Answered - Go to Answer
