Discussion topic: why no numbers for support
Message posted on 21 May 2024 05:07 PM
Talk about hard to get someone to talk to. I did ring in on the number like i was going to sign up for the first time was the only way i could get someone.
The servicce is nothing short of rubbish with the router not more than 4 feet from me the wifi is constantly dropping. I went over my logs on the router and the amout of times i am seeing service down or
PPP connection DOWN.
Voice IP Connection Down
Voice Disconnected
Voice DeInitialized
xDSL link down
Voice Disconnected
and many more. Some days its well over 15 times.
I rang two weeks ago got tech support to apparently make it that my numbe is private .. was it done ,... no still the same dispite the " tis will be 24 hours and your number will be hidden..... NOT ..
If i could leave this service i would do it in a split second as its abslote rubbish.
so come on give a number where you can talk to a human and not a stupid AI bot that just brings you in circles achiving nothing.
Message posted on 21 May 2024 05:17 PM
Re: why no numbers for support
It's not a secret. If you definitely need to call Sky you can call free by dialling 150 from your Sky Talk landline or a Sky Mobile, otherwise you can use:
https://www.sky.com/help/home
UK customers: Scroll down and click on ‘Need more help’ and it provides a 0333 number.
ROI customers: change the flag in the bottom right corner of the link to the ROI flag then scroll down and click on ‘Need more help’ and it provides a 0818 number.
(The forum doesn’t allow us to type the numbers in full).
You will find that similar to calling other large companies the start will be automated which may also try to send you back to the forum. Stay on the line as long as possible and don’t hang up.
Message posted on 21 May 2024 05:37 PM
Well like the service .. 150 does nothing. other than being deafend by a loud beeping as in no muber down the phone
https://www.sky.com/help/homeUK customers: Scroll down and click on ‘Need more help’ and it provides a 0333 number.
And no it dosnt provide any number and yes am logged in to my sky.
Had enough , since April the service has been rubbish , Next step comreg maybe they can get someone to call me that actually knows what they are talking about and not make sugestions that dont exsist.
Message posted on 21 May 2024 05:50 PM
150 doesnt work
Nop all it does is switch fro UK to ROI . no numbers are listed.
Message posted on 21 May 2024 05:56 PM
I've just tried it. It works. Change the flag (I presume therefore you're in the ROI) then click on 'Need More Help' and near the bottom it gives a 0818 number although Sky Ireland Customer Services may be closed now until tomorrow morning.
Message posted on 21 May 2024 06:04 PM
nop no option for Need More Help just the AI bot thats like as handy as a match in a firwork factory , I switched from UK back to Ireland and none offer the more help tis what it is , stuck in limbo and since i started this topic the broadband and voip have gon off 5 times .
Message posted on 21 May 2024 06:09 PM
It should look like the below
Message posted on 21 May 2024 07:53 PM
@far-far-away hope you are aware that @Daniel0210 is a customer like yourself he doesnt work for Sky - slight hint is the "not an employee" string on his posts.
Message posted on 23 May 2024 12:33 AM
Yip got through to support did a lot of tests , couldn't slove the issue and was promised a call back Wednesday morning.
Still waiting..
Message posted on 02 Jun 2024 10:32 PM
And here we are dispite 3 calls still waiting over two weeks for my call back. Shocking service by far , still have broadband issues only a few feet from the router and cat5 and cat6 lead direct to the box 1 mtr long many many times the speeds drop to below 30mb , for 500mb fiber thats just simply not good enough.
Things i had aasked to be done like withholding my nmber 4 times now and still not done , diabolical is an under estimate.
If I could leave this service without penelities i would be gone in a split second
Message posted on 03 Jun 2024 07:37 AM
@far-far-away raise a formal complaint see https://www.sky.com/help/articles/how-to-make-a-complaint-roi and ask to be released from contract. If Sky doesn't agree you can take your complaint toman independent arbitrator .
