Discussion topic: splitting 5
Message posted on 26 Nov 2024 06:46 PM
splitting 5
how i change 5ghz to 2.4 please
Message posted on 26 Nov 2024 08:35 PM
Re: splitting 5
White or black Sky Hub?
Message posted on 27 Nov 2024 12:02 AM
Re: splitting 5
If it's the White Hub you can't. Sky have decided we are all too thick to manage the router ourselves and spliting the SSID is one of the things you will find they have gone out of there way to lock down.
If you go through the my sky app you can turn off one band or the other...then you can use a different access point for the other band. Best you can do with that horrid thing I'm afraid.
If it's the black one follow this guide: https://helpforum.sky.com/t5/Broadband-Talk/How-to-separate-WiFi-bands/ba-p/3530610
