Discussion topic: Sky hub SR213 replacement to orbi guide
Message posted on 26 Nov 2024 10:26 PM
Hi fellow gurus
Recently had sky fibre 500 fitted
It's fttp with the new open reach ont fitted to wall. The sky hub WiFi wont reach to our farthest bedrooms in bungalow from it's position in living room. Ive got a Netgear Orbi dual set rbk50 package.
Is it possible to use this package instead of the sky hub sr213 as my router and satellite to increase WiFi so I can ditch the sky hub completely.
Could Anybody please give me details to correctly set this package up please as im a network noobie
Cheers for reading
Message posted on 26 Nov 2024 11:07 PM - last edited: 26 Nov 2024 11:09 PM
Re: Sky hub SR213 replacement to orbi guide
Are you in uk or ireland ? Either way so long as the rbk50 has the following fimware.
RBK50 |
V2.5.0.22 and above |
You'll be good to go
UK details
Dhcp option 61 cllent idenifier anything@skydsl|anything
Ireland settings
Connection type pppoe
Username anything@skydsl
Password anything
Vlan id enabled and type in 10
***Edit you said openreach ont so ignore the ireland info
Message posted on 27 Nov 2024 06:30 AM
Thanks cookie
Just to confirm the anything part in address in reply
Do you mean I have to type anything I want ? is there a correct amount of characters to use
Message posted on 27 Nov 2024 06:33 AM
Also the character after @skydsl is it a foward slash or that exact character as it looks like a long line
Message posted on 27 Nov 2024 07:07 AM
@Trojan2 you can replace the word anything with anything you like or leave it as it is it doesn't matter. If your Orbi only has one field for both user and password fields you need a pipe symbol to separate the two fields which is shown as | when typed
