Discussion topic: broadband below guaranteed speed
Message posted on 14 Jan 2024 05:32 PM
Hi,
I joined sky on 14th December and my broadband has been below the minimum speed guarantee since 16th December I am only getting between 55 and 57mb and my minimum speed gurantee is 60mb.
When i tested it on 14th and 15th i got 65.1 on 14th december and 63.1 on 15th december
I know i can get more and when i used to be wirh plusnet i used to always get between 66 to 68mb. I have had sky engineer come and look at it and he changed the master phone socket. But that has not made a difference at all
I have attached both screenshots the one i tested when i was with plusnet and the one i have now tested with sky
Both times I have tested with a PC connected directly to the router with ethernet cable,
Sky's service checker reports no issues.
What options do I have to try and resolve the issue?as i know my line suppport more speed but sky engineer was not helpful he just kept saying this is the maximum your line supports. I also showed him the speedtest from plusnet.
Message posted on 14 Jan 2024 05:47 PM
Re: broadband below guaranteed speed
@Sajag Please can you post your router stats so the forum can advise on any issues. This link explains how to do that https://helpforum.sky.com/t5/Broadband/How-to-find-your-Sky-Broadband-router-stats/td-p/2855717#
Message posted on 14 Jan 2024 05:59 PM
Thankyou for your help. Please find my router stats
Message posted on 14 Jan 2024 06:07 PM
@Sajag You are getting the speed quoted as per the router stats.
Message posted on 14 Jan 2024 06:17 PM
I am so sorry i maybe i am getting wrong but when i check the speed using sky service checker i am getting 58.5mb only see screenshot similar to what I get when I have tested with a PC connected directly to the router with ethernet cable
Message posted on 16 Jan 2024 10:57 AM
If the Sky checker is showing that then you have grounds to claim money back as you are under the minimum or you can be released from contract.
