14 Jan 2024 11:32 AM
Hi all, im after advice please, I'm having issues with my WiFi for about 6 months now...
The WiFi kept disconnecting and we had the orange light on the router for a few minutes then would come back several times a day....
The openreach enginner rejumpered my connection at the frame twice... second time of trying that now seems to have stabilised that issue.
We've also had a new phone socket and 2 routers tried.
However I still get call drop outs from teams at least once a day with a poor network connection warning or buffering once or twice a day streaming from my tv....
We have sky multiroandwhich I know runs via a mesh network.
im convinced this is the issue I think its causing interference. Does anyone have any suggestions or other thoughts on whst the issue could be?
ive seen suggestions on forums to change the main sky box 5ghz settings to 40mhz rather than 80 so will try that for a few days.
Sorry I forgot to say, I'm in a flat so I don't think distance from the router etc is the issue, but me being in a flat could possibly be why the sky q mesh is causing issues?
14 Jan 2024 01:03 PM
Posted by a Superuser, not a Sky employee. Find out more@Peahead Could you please post your router stats following the link below.
14 Jan 2024 01:22 PM
Hi @Highlinder
Sorry here are the stats
Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time WAN MER 976760 2705444 0 34862 92908 03:16:11 LAN Down 0 0 0 0 0 00:00:00 WLAN (2.4 GHz) Up 20915179 6781011 0 13540 4591 02:10:38 WLAN (5 GHz) Up 69867733 32746616 0 0 0 02:10:34
14 Jan 2024 01:26 PM
Or this may be easier to see...
14 Jan 2024 02:50 PM
Posted by a Superuser, not a Sky employee. Find out more@Peahead Can see from those stats you have had a drop on the connection. Are you able to see the lights on the router when your drop out of teams and what happens?
14 Jan 2024 02:58 PM
Yes I can usually or when I have a drop I check immediately...
Previously we would get an orange internet light on router.
However since the openreach engineer visit a month or so ago all lights stay green but we still seem to get interruptions.
This week I had 3 dropouts that I recall when I was working this week and each time all lights were green with connection restored a minute or 2 later...
14 Jan 2024 03:23 PM
Posted by a Superuser, not a Sky employee. Find out more@Peahead Best to check the stats to see if they have changed or something has re-started on the router, that being the Wi-Fi frequencies or even the WAN connection. To narrow down what is the cause of this issue.
14 Jan 2024 03:31 PM
OK thank you i will take a snap of them if it happens again.
After looking on the forums where some users were saying their sky q mesh causes interference I've changed my main sky q hub 5ghz wireless from 80 mhz to a 40 mhz channel this morning. Do you think that could help?
16 Jan 2024 10:54 AM
Posted by a Superuser, not a Sky employee. Find out moreYes that could help as you are essentially reducing the chance of interference on the channel Sky Q is using by only using half the channel width you were using before
