10
This discussion topic has been answered Discussion topic: broadband and Talk
This message was authored by: rams01
broadband and Talk
Hi
For the past two days the internet keeps dropping , it was doing it all day yesterday(28/3),today it is the same,  i am sending this messge before it goes off again and also the land line is dead.
Avatar for rams01
Level 2 icon
This message was authored by: rams01 Answer
Re: broadband and Talk
Hi
Just to let you know that after nearly a week with the internet being on and off and no phone line I had just given up and then suddenly a BT Engineer turned up and fixed everything. No idea he was coming he replaced the socket and the internet cable now feeds direct in that socket.
First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
Avatar for rams01
Level 2 icon
still coming on and off, landline is still dead.
What is going on
@rams01 wrote:
What is going on
Probably a fault on the individual circuit to your address, especially if it's an FTTC connection: with tens of millions of these in use, a percentage inevitably have issues at any particular time.
This message was authored by: Simon2605
Hi , getting the same thing here, on and off all week since 25th march.
done all the usual sky checks and nothing.
but we have had a open reach box knock over by a car and had the problem ever since. But sky saids there's no problem in the area mmmmmmmmm
Avatar for rams01
Level 2 icon
Getting really tired of all of the problems we def need sky to get this fixed and get the landline working as well
@rams01 @Simon2605
You'll need to persist with actually logging a fault with Sky: a forum post doesn't do that.
Note 'no problem in your area' refers to known wide scale outages, not individual properties.
No worries there I have been doing that 😉
Avatar for rams01
Level 2 icon
Hi
@rams01  Has this fixed your issue now and your broadband is working correctly now?
Avatar for rams01
Level 2 icon
Hi, yes it's fixed the problem everything working.
