Discussion topic: Work Laptop Connectivity Issues (ZScaler)
Message posted on 25 Sep 2024 01:52 PM
Hi,
I’m having network issues connecting with my work laptop, they use ZScaler VPN(can't be disabled.)
Pages don't load and I get the error: ERR_CONNECTION_RESET
Work IT say it's a Sky Issue.
I’ve tried the following on call with a Sky Agent:
Reset router with WPN Button on side
Disable/re-enable sky shield
Turn off IPv6 on laptop
Used wifi and ethernet
Restarted work Laptop
Changed WIFI Security to WPA2
none of this made a difference.
Reading online I’ve seen Sky Agents from the tech team change the router config: https://helpforum.sky.com/t5/Broadband/Zscaler-not-authenticating/m-p/4747217
Is this something that can be done?
Best Regards
Message posted on 25 Sep 2024 01:55 PM
Re: Work Laptop Connectivity Issues (ZScaler)
Additional Info:
I am using a Sky Max hub with Gigabit Internet.
connected via ethernet but have tried wifi too, same issue persists.
Message posted on 25 Sep 2024 01:58 PM
It could be MAP-T, try enabling UPnP in the hubs settings, this will force you back to a 1:1 IP mapping
Message posted on 25 Sep 2024 02:03 PM
@jamesn123 Many thanks for getting back to me so quickly.
Enabled this there now, unfortunately same issues are still persisting.
Message posted on 25 Sep 2024 02:05 PM
It should be pretty instant but try giving it 15mins then reboot your hub and try again.
