Discussion topic: No broadband in Orpington are
This message was authored by Kelly19801 This message was authored by: Kelly19801
Does anyone know what's going on with broadband in Orpington area? I'm trying to work from home and mine and neighbours in the street have no connection
This message was authored by Ed43 This message was authored by: Ed43
Re: No broadband in Orpington are
Same with mine. In Orpington and having WiFi issues. Unable to wfh.
This message was authored by Pete111 This message was authored by: Pete111
Same here. I suddenly lost Internet signal. How can one report thus to Sky?
This message was authored by Matt1014 This message was authored by: Matt1014
Same here just a pulsating green light on the hub
Used service checker and no use states that no issue apart from my WiFi is switched off and to sign in to fix and when I try this I get a message stating no devices connected so I am unable to.
This message was authored by The+OOh+la+la This message was authored by: The+OOh+la+la
Same issue
Kelly19801
No idea. I can't find that option. And when I do the service status check online it's says everything is ok! My neighbour has said he is with Vodafone and he can see there's a broadband issue in our area. Apart from VM, they all use the BT Openreach network apparently but I can't find anything for them either!
This message was authored by Sazza1977 This message was authored by: Sazza1977
Am on the phone to sky now.  Apparently nothing showing the system as an outage?!  Currently on hold!!!!!
They are sending an open reach engineer to the area.  SLA for fix is 2 days.. awesome!
Same thing they told me. I have implored them to make super urgent as quite a number of us are affected. Hopefully, they can send an engineer in the next few hours.
@Ed43 Openreach work to their own priorities unfortunately but area faults are checked out but how long it takes to get the service back up depends on what the fault is a minor issue can take hours a major one like a car taking out a street cabinet a couple of weeks.
The 2 working day SLA is met in 80% of cases and beyond that you will be compensated see Customer Auto-Compensation | Sky Help | Sky.com
This message was authored by curiousgiraffe This message was authored by: curiousgiraffe
Me too. no internet for 2 days now.
This message was authored by Pranab This message was authored by: Pranab
Re: No broadband in Orpington area
Sae here too
This message was authored by GeorgeYu This message was authored by: GeorgeYu
Same here. Sky claims there is no outage but there is.
