Discussion topic: Wifi keeps dropping on Sky Max Hub
This message was authored by: JulieJY
My wifi keeps dropping out in my upstairs rooms, particularly in the afternoon. I bought the Max Wifi for a better signal than previous supplier but its just the same. Can I get a booster or Sky pod to try?
Re: Wifi keeps dropping on Sky Max Hub
@JulieJY if you got the Sky Max hub as part of the WiFi Max bundle call Sky and they should send you an extender pod to fit halfway between the room with poor wifi and the hub.
