Discussion topic: No voice light, connected but no internet
This message was authored by: Stevenandlolly4
After a power outage, the light for voice on my router has gone out and no Internet access when connected to broadband over WiFi, ethernet made no difference. I've gone through troubleshooting, I've restarted router and the fibre inlet, I've checked the broadband checker and the online configuration page and have had no change.
Re: No voice light, connected but no internet
@Stevenandlolly4 this fault normally is caused by an issue with the server managing your connection. Normal fix is to power down your hub for an hour which should mean you connect to a different nodecwhich is working properly.
