Discussion topic: Wifi dropping
This message was authored by: Hrithik1
Wifi dropping
My wifi has been dropping for a minute or so all day today. Don't see any reported issues on sky
Re: Wifi dropping
@Hrithik1 Could you please post your router stats following the link below.
Avatar for Hrithik1
Re: Wifi dropping
pls see below
Re: Wifi dropping
@Hrithik1  Is your broadband still down or is it back up. If it is still down follow the link below to see if a fault is found and it should let you book an engineer.
Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
