3
This discussion topic has been answered Discussion topic: Home Move - BT open reach connection point
This message was authored by: Turner83
Moving into new house which has just been refurbed and it seems the BT openreach port has been removed and the area plastered over. THe external connection is still there on the outside of the house.
Will the sky engineer be able to reinstall the port or will I need BT OPen reach to reinstall it?
Re: Home Move - BT open reach connection point
@Turner83
OK: FTTP is not available, so the address does require a copper Openreach line to a master socket.
Typically that will need Openreach attention, but this has to be booked through the ISP.
@Turner83
Putting the address into the BT Wholesale Availability Checker should indicate which provisioning type is applicable.
Avatar for Turner83
thank you, here is what it says
@Turner83
