Discussion topic: Wifi dropping out
Message posted on 24 Mar 2024 03:53 PM
Wifi dropping out
Every day and/or night the wifi or broadband drops out - the TV is affected and our phones etc are using our data.
I continually have to reset the box to enable the WiFi to connect again - considering what I post per month AND the increase added it is not good enough. A simple connection should be easy. Any suggestions what can do?
Message posted on 24 Mar 2024 04:38 PM
Re: Wifi dropping out
@Kooky3101 if you post your Sky hub's connection stats forum members should be able to help see Find your Sky Broadband router statistics
Message posted on 19 Jun 2024 07:34 PM
Thank you for your reply.
after months of the wifi dropping out I finally have been supplied with a new router. Further problems are that I cannot get my printer or plugs to connect!
Message posted on 20 Jun 2024 10:39 AM
You probably need to split the WiFi bands.
https://helpforum.sky.com/t5/Broadband-Talk/How-to-separate-WiFi-bands/ba-p/3530610
