Discussion topic: Wifi connection
Message posted on 02 May 2025 10:27 AM
Wifi connection
My WiFi connection keeps cutting out on my laptop including my ethernet cable
Message posted on 02 May 2025 10:41 AM
Re: Wifi connection
My internet is down totally.
Message posted on 02 May 2025 10:57 AM
Re: Wifi connection
@Staci4 & @EMmoore Can you please run the service checker, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
After the service checker completes and if it comes back green all good can you click on broadband to run an updated test please. If you get amber or red please follow the on screen instructions.
Message posted on 03 May 2025 01:24 PM
WiFi **bleep** keeps cutting out i want fibre plugging to my house
I would like full fibre to my house not by WiFi to a little green box...
Message posted on 03 May 2025 01:26 PM
Re: WiFi **bleep** keeps cutting out i want fibre plugging to my house
Have you checked via your account to see if fibre is available at your property ?
Message posted on 03 May 2025 01:27 PM
Re: Wifi connection
I would like to have fibre actually fitted correctly, I work from home and I need the Internet amazing!
Message posted on 03 May 2025 01:58 PM
@Staci4 Your current broadband is delivered by Fibre to the cabinet and then to your home over copper cable, there is no wifi involved at all between the exchange, cabinet & your home.
The wifi signal is provided by your router inside your home only.
