4
This discussion topic has been answered Discussion topic: Humming Noise
This message was authored by: Lesley0911
Humming Noise
Have recently converted to full fibre, big mistake, we can now hear a loud humming over most of the house. Narrowed it down to the broadband, switched it off at the mains and the noise stopped, scared to turn it back on now
This message was authored by: JimM1 Answer
Re: Humming Noise
@Lesley0911 Turn the OR ONT on first, will take a few minutes to boot up to the green lights, see if you are getting any humming off it, can just be the range of frequency that you have some people hear and others not.
Couple minutes later the Sky router, it takes around the five mins to boot, same listening again. You can let us know of the findings.
Re: Humming Noise
@Lesley0911 Which part did you switch off to clear your noise? Sky Hub or OR Openreach Modem
Avatar for Lesley0911
Re: Humming Noise
Hi Jim, I turned off at the mains so believe both were switched off
Re: Humming Noise
Re: Humming Noise
Hi, I am so sorry for the late reply, just found the responses in my junk folder.
This did indeed fix the problem, once switched back on, the humming had disappeared.
Thank you so much for your advice.
