Discussion topic: WiFi not working
Message posted on 18 Feb 2025 01:01 PM
WiFi not working
New router put in. Says it's connected to the wifi but all devices say there's no internet.
Message posted on 18 Feb 2025 01:42 PM
Re: WiFi not working
As you have a new hub you now need to setup each wireless device again by having them search for your new Sky network name then use the password that is on the card and the hub itself to connect them up to your Wi-Fi.
Message posted on 18 Feb 2025 02:13 PM
Thank you. I ended up calling sky! There was a sneaky wps button to reset the router. It blended in with router so was not easy to spot at all.
All happily fixed 🙂
