3
This discussion topic has been answered Discussion topic: WiFi issue
This message was authored by: Adam8787
WiFi issue
For the last month or so my WiFi keeps dropping off or running slow on multiple devices. For instance, my laptop keeps dropping and day no WiFi. My phone constantly fails to load web pages saying slow or no connection and my tv os really slow loading apps like Disney plus. This all worked fine up until approximately a month ago. I have tested the WiFi on the mysky app and it says no issues but there clearly are. Do you think the router has an issue? All wores etc are plugged in, nothing has changed with my setup. Thanks
Re: WiFi issue
@Adam8787
Try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Select "No, I still need help" at the bottom on the above link.
Re: WiFi issue
@Adam8787
Was it this line test that you ran:
Avatar for Adam8787
Re: WiFi issue
Thanks for the reply. Yes that's the test I've ran and it comes back all clear. Do you know if there are any other options. I should add that it's also an issue on wired connections
Re: WiFi issue
@Adam8787
