1
This discussion topic has been answered Discussion topic: Low WiFi connection
This message was authored by: Emine__
Low WiFi connection
My tv apps are either very slow or not loading. The WiFi isnt strong enough
Re: Low WiFi connection
@Emine__
Try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Select "No, I still need help" at the bottom on the above link.
@Emine__
