1
This discussion topic has been answered Discussion topic: Can I block a device getting wifi
This message was authored by: Craigdaws
Can I block a device from getting WiFi?
Re: Can I block a device getting wifi
@Craigdaws
To permanently remove access you'd need to change the WiFi password (and then update it on all the devices which you do want to have access)
If you have the WiFi Max subscription supplement and a white Max Hub then Parental Controls can limit access by individual devices.
@Craigdaws
