09 Feb 2025 11:02 PM
Very slow.
09 Feb 2025 11:03 PM
Has this just happened or an ongoing issue? It sounds like a fault that needs reporting tbh
10 Feb 2025 06:49 AM
Have reported and they said to "stabilize" the network it will take 10-14days. I'm paying for 34GBP for max of 60mbps. I might switch the network to Virgin.
10 Feb 2025 06:59 AM
Posted by a Superuser, not a Sky employee. Find out more@Ayano you have 31 day cooling off period for a new connection. However be careful if measuring speeds over wifi as you often dont end up measuring the wifi speed in your home which isnt guaranteed - check the speed shown in the Connection Check in the My Sky app which is what drives the guarantee.
If you have a black Sky hub post its connection stats so forum members can give you an idea of the issue see Sky Hub statistics
