Discussion topic: WiFi down
Message posted on 02 Nov 2024 09:47 PM
WiFi down
I have tried turning router box on and of a few times leaving it off for min at a time. WiFi still not working. Cables are fine, have not moved any equipment.
Message posted on 03 Nov 2024 07:15 AM
Re: WiFi down
@Timjacob standard advice is to check the lights on the the hub -see https://www.sky.com/help/articles/hub-lights-explained-start - If they show the hub has lost connection to the line and a simple reboot doesn't sort the issue is to log into the My Sky app and see if the service checker tells you Sky are aware of a fault affecting your line. Don't worry if it says everything is fine as that was the position when it last tested the service.
If it doesnt tell you it's a known fault call Sky their lines are open from 8am to 9pm
